Originally Posted By: Bill in Utah
Originally Posted By: jim302
Originally Posted By: Nick R
Honestly, a CEL on a new car wouldn't bother me that much, no matter the brand. I mean seriously, they are expensive, but even the cheapest cars are massively complicated. Hundreds of thousands of parts. It's impossible to have everything be perfect, every single time.
This is exactly how I would feel. A lot of cars even have TSBs for common causes for a check engine light. Sometimes, an improved part is needed, or just an inspection of a problem area that was found after assembly. In some cases, the fault code is completely bogus due to a software glitch in the PCM, in which case there will probably be a software update available.
After taking it to the dealer, it is likely that the truck will be in & out in an hour if they aren't too busy.
The dealership SHOULD HAVE updated it BEFORE delivering it to the CUSTOMER *IF* this is the situation.
I've had CEL on vehicles that were new (its been a long time since) but something that was "improved" or TSB really should be done WELL before the customer EVER sees the vehicle. That IS customer service.
I don't care if the truck comes in and out under an hour. Its a hour that should NEVER be done *IF* the vehicle/dealership/manufacture had a clue. (again *IF* it is a upgrade or TSB that happened before delivery date)
The customer has a life too. And its their hard earned $$ and TIME that is wasted here.
JMO, Bill
Call up your congressman and tell his to start repealing consumer protection laws.
Many states have consumer protection laws that indicate an automobile can not be repaired without notifying the customer. This includes pre-delivery vehicles. If a car has been fixed for any reason prior to the customer taking delivery, the dealer is obligated to inform the customer before delivery. This also gets into very murky water about whether it is a "new" car anymore and how much the repair de-values the car. There's been lots of litigation on cases like this if you think lawsuits are light reading.
The exception is if it is a recall campaign. Those are safety and emission related, regulated by NHTSA and the EPA, respectivly. These typically come along with a "stop sale" at the dealer level in which none of the vehicles involved with the campaign may be sold until the recall inspection or correction has occured.
Also, TSBs are also written as a "Vehicle may exhibit..." or "Customer may experience..." type of repair. That is, they don't affect all vehicles. If the customer doesn't come in specifically complaining about the problem, the recall doesn't apply. They are not blanket repairs intended to fix the entire fleet, but rather only those vehicles which exhibit a specific condition. There are numerous reasons why this is and none of them have to do with screwing over the customer.
Generally, unless it's a legit problem that was identified during the pre-delivery inspection, it gets delivered. A dealer isn't going to go through an entire vehicle throwing new software in every controller and performing every single published TSB, most of which will never affect the vehicle. Talk about a waste of time and money.
