Pennzoil Ultra 5w20 / 7500mi / '08 Ford Fusion 3.0
by sdude2k2000
Today at 12:59 AM
Hairline Cracks in Radiator
by Merkava_4
Today at 12:05 AM
Super Tech Syn 5/30
by RevRider
Yesterday at 11:31 PM
Installing a dish washer.
by ram_man
Yesterday at 10:37 PM
Strangest Three Wheel Car Ever
by Fsharp
Yesterday at 09:57 PM
Remove Gasoilne and other Blowby Gasses
by landtoy80
Yesterday at 09:48 PM
Trans Am said goodbye to his battery today.
by ls1mike
Yesterday at 09:39 PM
Lil Big Rig - I want one
by montero1
Yesterday at 09:01 PM
[Cut Open] Champ PH2808 - Torn Pleat
by Bud_One
Yesterday at 08:41 PM
2015 silverado dealer oil change
by Realtech214
Yesterday at 08:27 PM
delo 400 $17/gallon at walmart now?
by motor_oil_madman
Yesterday at 08:23 PM
Looks like Classics are going bye,bye at WM
by chainblu
Yesterday at 08:18 PM
robco, TrogDorInjection, wytenow, maxud, OrchardAuto
56875 Registered Users
26 registered (David1, Char Baby, 01_celica_gt, CRXPilot, Abakev, 1 invisible), 473 Guests and 207 Spiders online.
56875 Members
66 Forums
244478 Topics
#2386719 - 09/24/11 05:09 PM What tire pressure on Ariens snow thrower?
fred9xx Offline
Loc: Connecticut
Model 924118, 24', 8 hp, 8 years old.
Tires are very nubby, like Snow Hog. Size is 16/4.8 x 8.
I have NEVER checked the tire pressure until today. Hardly moved the needle. Sidewall has 20 lb max. Driveway is steep hill so I don't want to over inflate. Should I use 10 or 12 lbs or? I will check pressure again when temp. drops.
Thanks
07 SI
05 Highlander
96 Camry Wagon
#2386723 - 09/24/11 05:18 PM Re: What tire pressure on Ariens snow thrower? [Re: fred9xx]
2oldtommy Offline
Loc: Ohio
I run 9-10lbs in my ariens tires. this is a 38 yr. old unit. I believe this should be OK for you . How about chains for that steep hill? Your tires are probably tubeless. You want to make sure you don't break the rim seal. FWIW-Oldtommy
#2386733 - 09/24/11 05:28 PM Re: What tire pressure on Ariens snow thrower? [Re: fred9xx]
mrsilv04 Offline
Loc: Illinois
I have a 22" two stage, and I keep about 8-10 psi in the tires.
Whatever you do... do NOT speed through the town of Gauley Bridge, WV.
#2386738 - 09/24/11 05:36 PM Re: What tire pressure on Ariens snow thrower? [Re: fred9xx]
fred9xx Offline
Loc: Connecticut
Oldtommy,
Thank you.
Yes, I am now thinking about chains. (While I could say I haven't needed them in the last 8 years. A few years ago the machine did slip going up hill. I went down with it and it then slid past me. I now have "chains" for my boots(from LL Bean). Not to mention that I'm now 68. (I retired last April, so I guess I now have more time to think about these things.)
Any suggestions on where to look for chains on line?
Thank you.
07 SI
05 Highlander
96 Camry Wagon
#2387045 - 09/24/11 10:26 PM Re: What tire pressure on Ariens snow thrower? [Re: fred9xx]
dwendt44 Offline
Loc: Central Wisconsin
Simplicity calls for 8 lbs. on the larger models.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
#2387385 - 09/25/11 11:43 AM Re: What tire pressure on Ariens snow thrower? [Re: dwendt44]
fred9xx Offline
Loc: Connecticut
Thank you for your input!
07 SI
05 Highlander
96 Camry Wagon
#2387403 - 09/25/11 12:11 PM Re: What tire pressure on Ariens snow thrower? [Re: fred9xx]
JTK Offline
Loc: Buffalo, NY
My experience with the Snow Hog tires is; You'll get real good traction if you keep them soft, maybe around 6psig. Real deep, heavy snow where your doing long straight runs it's great.
For lots of tight spot maneuvering, your better keeping them stiff @ 8-10psig.
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#2387496 - 09/25/11 01:58 PM Re: What tire pressure on Ariens snow thrower? [Re: fred9xx]
fred9xx Offline
Loc: Connecticut
JTK,
I'll follow your approach.
Thanks
07 SI
05 Highlander
96 Camry Wagon
