Our MDX has begun to generate a light howl at speed, mostly heard only on smoother pavement...and lately, it's beginning to get louder on longer right-hand sweeps of the road and a little quieter on longer left-hand sweeps of the road. So I'm suspecting that the left rear hub bearing is beginning to make noise.
I've not seen a hub bearing like this on a driven hub. Most of the ones I've seen bolt to the hub with 3 or 4 bolts. This one is a simple cylindrical bearing driven into the hub with a press. So it's not really DIY replaceable.
But I'm wondering if it's DIY serviceable. This car sat for extended lengths of time when my folks owned it, so I'm thinking the bearing may have gotten dry. Would it be possible at this point, despite the fact that the bearing is already making noise, to disassemble everything and grease it to quiet it down? Or is the fact that it's already making noise mean that it's already scored or damaged, and no amount of grease or TLC will restore it back to quiet?
I have no qualms about disassembling everything to try and fix this myself, but if it'd be a futile effort, I won't waste my time and will just take it to an indy shop for repair.
Thank you!
Thank you!
