I know I've seen it somewhere and I didn't find it searching, but other than trial and error is there a mathematical formula for figuring tire pressure?
I just bought new tires but bought a bigger tire than OEM. Went from 265/70/17 to 285/70/17 on my Chevy Silverado. The original tires wore very evenly at 36 PSI as the door sticker stated. I've put about 200 miles on the new 285's at 36 PSI, and although it's not a high tech method it appears the centers are wearing much quicker just by looking at those new little nubs on the tires. Tried a chalk test as well which confirmed the edge of each side of the tire tread was not contacting the ground.
Does it stand to reason that since the new tire has a higher load rating that I would need slightly less PSI? At any rate I lowered each tire down to 33 PSI to see how that does.
