One of my friends ended up with an old MTD tiller with a 5 horse Briggs & Stratton 140200 horizontal engine that has a Pulsa Jet carb. It looks to be 40-45 years old probably, but I have no idea since I haven't uncovered the serial number yet. I definitely think it is older than the circa 1975 Techumseh powered Sears tiller I "flipped" a couple years ago.
It was clear right away that it needed a new tank to carb gasket and a couple other gaskets/grommets. My friend was able to get it to run by spraying gas down the carb though, so it's definitely worth tinkering with. I have a new carb to tank gasket, diaphragm, intake gasket, valve cover gasket and grommets, fuel pickup tubes, and spark plug ready to install. I'm hoping those parts will be all it needs to be a strong runner, but first I need to finish cleaning it up.
The only thing I haven't been able to figure out with it so far is what is going on with the choke. It's not like any other choke setup I've seen. There's a round metal grip at the end of the carb that says "choke" on it and an arrow clearly pointing outward. I can't get it to budge though, either out or by twisting from side to side. It appears to maybe be a tube inside the barrel that slides to close the air filer end. I sprayed the carb down with Deep Creep last night and have let it sit, but the choke still won't move. There's not a lot of corrosion on it, but maybe enough to make a metal on metal tube stick. Unfortunately the parts diagram doesn't show the choke separate from the main body of the carb.
Has anybody ever freed up one of these things? Any tips to loosen it, or am I just trying to use the choke wrong? I figure if it's stuck for good, starting fluid will do the trick, but since I have the carb off the tank anyway it would be nice to get it working. I haven't tried Vice Grips or anything yet because I'm not sure how delicate it is.
