1. What kind of vehicle you have
2006 Lotus Exige
2. What your owner's manual says -- not just viscosity, but certifications (look for acronyms like API SM, ILSAC GF-4, etc.) and change intervals as well
Viscosity: 5W/40
Quality Standard: API SJEC, ILSAC, ACEA A3
Normal driving oil change interval: 7500 miles
With vigorous driving: 4000 miles
3. Where you live
Bay area, California. Very mild all year round. Temps from 60F to 94F. Average is 70-80 most of the year.
4. How you drive (easy? hard? fast? slow?)
Hard once or twice per commute trip, never until oil is sufficiently warmed up. If the oil is cold I always shift before 3,500 RPM and double clutch each shift. (sounds like a lot but it's a challenge to shift sooner in a lotus haha)
Occasional autox, less than once a month.
5. What your daily drive is like (short trips? long trips? city? highway?)
Commute is either 7,10, or 12 miles long. Usually half city half highway.
Will be going to a lot of meets though and going on 30-40 mile trips, maybe longer.
6. Whether your car has any known problems
The engine is pretty high strung. Here's the specs:
Designation: 2ZZ-GE (toyota celica GTS, toyota corolla XRS, toyota matrix XRS, lotus elise, lotus exige)
cylinder configuration: inline 4
capacity: 1793cm^3 (1.8L)
bore: 82mm
stroke: 85mm
camshafts: chain driven DOHC 4 valves per cylinder. Power camshaft engages at 6,400 RPM.
valve actuation: inlet: variable timing and lift
exhaust: variable lift
compressoin ratio: 11.5:1
firing order: 1,3,4,2
Max continuous engine speed: 8000RPM. Ocassionally allowed to 8500, not continous.
Minimum octane: 91
Peak power: 190bhp @ 7,800 RPM
Peak torque: 138lb/ft @ 6,800 RPM
Known engine problems:
http://www.lotustalk.com/forums/f25/camshaft-cover-defect-causing-rocker-arm-breakage-p1302-50594/
My question:
I want to run a 10W-40 instead of a 5W-40 to help protection at higher engine temps. The engine normally stays between 190-200F consistently while running. It can get as high as 210F in traffic or waiting in line to autocross. I heard 5W-40 breaks down easier at higher temps due to the VII additives so I figured a 10W-40 would be better but I wanted to ring the experts first.
Here's the oil I'm looking at using:
http://www.amsoil.com/storefront/amo.aspx
2006 Lotus Exige
Viscosity: 5W/40
3. Where you live
bore: 82mm
stroke: 85mm
Minimum octane: 91
My question:
