'90 quadrunner 4wd suzuki
It has a little over 4,000miles on it. It is just used for mild work around the yard. It has been neglected with not very many oil changes in the past few years because it sits up more than it is used. The question is it desperately needs to be running a thicker oil in it to keep from burning it like crazy out the exhaust( under load it wants to just smoke...blue smoke that is). Which oil additive would y'all recommend or should I just switch to thicker oil? Not something as thick as running SAE 30? Or would I need to be running something as heavy as 15w40 or something different. It's a '90 model and it may need something more but what can slow the process of the oil just burning like it is??? I could figure it out on my own but wanted to get any opinions firsthand or input from any of you and go from there.
Just changed the oil not long ago with some castrol 10w40oil not the special atv oil that suzuki recommends. Needs something a bit better since I am using it for a project that I am towing a fairly good sized trailer with. Need some feedback.
