215,000 miles, bought new it has never had anything but the old Honda fluid. My father was going to trade it in five years ago and I bought it from him instead. At that time, there was a lot of metal paste on the transmission drain plug. He was having the dealer change the ATF fluid every 30,000 miles.
Because it is so easy to change the transmission fluid, I started changing it every oil change. Really, less than 2.5 quarts are coming out each time. I'm also getting some metal paste even after 4000 miles but not much.
Now we come to the end of the old Honda fluid. It's all the car has ever had, but I'm not that impressed because of the amount of metal paste. Thinking of moving to the new Honda fluid but I also have a 2000 legacy that has had mobil 1 transmission fluid since the first 20,000 miles. I change it every 25,000 to 30,000 and it has 214,000 and no ATF problems.
I live in the mountains and the local Sube shop (independent) says it's the most they have seen here without a rebuild. Specs are better for Mobil 1 than new honda fluid. Thinking of just using Mobil1 for the accord, after coupon, it's only about $6 per quart at advance.
Advice? Thanks!
Advice? Thanks!
