Fram Ultra XG10060 Cutaway...
by AnthemBassMan
05/24/16 04:11 PM
The Vole (MS) now deceiving users to install W10
by simple_gifts
05/24/16 04:04 PM
5w20 + seafoam + hot weather + towing = ?
by meborder
05/24/16 03:15 PM
Chewbacca Mom & James Corden
by CharlieBauer
05/24/16 02:45 PM
This Radiator Looks Good to Me!
by Miller88
05/24/16 02:38 PM
Bill Cosby's sex assault case going to trial
by Mr Nice
05/24/16 02:25 PM
This is one reason I prefer to do my own oil
by SirTanon
05/24/16 01:37 PM
Recent discovery of SatbiliTrack failure Mode
by MolaKule
05/24/16 01:11 PM
Costco Insurance discountn going away?
by stockrex
05/24/16 12:56 PM
4 Wix Oil filters and 1 Mazda OEM AF (skyactiv)
by badtlc
05/24/16 12:48 PM
FYI, At&t Implements data caps today
by badtlc
05/24/16 12:12 PM
Top Tier Gasoline = only 5 miles more per tank?
by Hyde244
05/24/16 11:45 AM
WeekendWarrior, emily, lex73, showstopr30, any_user
57966 Registered Users
77 registered (AandPDan, 2oldtommy, Al, 440Magnum, 94astro, 4 invisible), 1843 Guests and 97 Spiders online.
57966 Members
66 Forums
249352 Topics
#2366612 - 09/03/11 11:51 PM Grease Expedition axle behind front wheel bearing?
Fitz98 Offline
Loc: Florida
I have noticed on my 4x4 front axle that there is a grease seal pressed in the steering knuckle behind the front wheel bearing that the axle fits into. There was a little grease in there when I removed the axle and bearing. Is this area supposed to be greased around the area between the steering knuckle and the axle, or is that seal just a dust cap? If greased, how much...fill the space between the wall of the axle and the wall of the steering knuckle?
#2366740 - 09/04/11 08:42 AM Re: Grease Expedition axle behind front wheel bearing? [Re: Fitz98]
Trav Offline
Loc: MA, Mittelfranken.de
What you are looking at is the hub/axle seal. This seal is to keep water from entering the hub and splines and keep the grease that is on the splines at assembly from leaking out.
This helps keep rust from turning the thing into a solid unit.
Grease the splines up with a water resistant grease like Mobil 1 red when assembling.
Edit: No maintenance is required on this part.
Edited by Trav (09/04/11 08:47 AM)
#2366870 - 09/04/11 11:01 AM Re: Grease Expedition axle behind front wheel bearing? [Re: Trav]
Fitz98 Offline
Loc: Florida
Thanks Trav,
So do I pack the area to the wheel side of the grease seal in the void between the hub and the axle, or is that a dry unlubricated area?
#2366874 - 09/04/11 11:08 AM Re: Grease Expedition axle behind front wheel bearing? [Re: Fitz98]
Trav Offline
Just smear a little grease around the seal and on the axle splines and your good.
Fitz did you ever check that clutch fan?
#2366888 - 09/04/11 11:25 AM Re: Grease Expedition axle behind front wheel bearing? [Re: Trav]
Fitz98 Offline
Loc: Florida
Great, thanks!
Clutch fan? I am assuming you mean fan clutch?
No, I didn't. What is the proceedure to check that?
I sort of ruled it out, since the sound was synchronized with the rotation of the tires.
I have narrowed it down to a bad wheel bearing (dry). There was a fair amount of grease in the hub. I was assuming it leaked out from the bearing hub.
I hate that I had to buy a cheap replacement bearing, but it was the only one in stock locally, and also have money issues.
It will help me diagnose if that is the problem, and at least get me mobile for now.
It's an NTP. Should I be concerned about the performance of this?
#2366912 - 09/04/11 11:46 AM Re: Grease Expedition axle behind front wheel bearing? [Re: Fitz98]
Trav Offline
Just grab the cooling fan blades and check for play, it should turn freely with slight resistance.
I had a similar noise years ago and because they free wheel the noise didn't stay in sync with engine rpm, the blades just hit the fan shroud when giving or letting off the gas.
When you said it sounded like fan blades hitting plastic this fan clutch was the first thing that came into my mind.
I have no experience with NTP. SKF, Timken, National, F.A.G and a few others seem to be preferred. The NTP maybe okay i don't know.
Next time try Rock auto if you can wait a few days.
Edit: Did you try holding the brake and giving it gas in drive to see if it made the noise?
Edited by Trav (09/04/11 11:48 AM)
#2366916 - 09/04/11 11:51 AM Re: Grease Expedition axle behind front wheel bearing? [Re: Trav]
Fitz98 Offline
Loc: Florida
What bearing do you like?
I will check the fan blade. When the noise started, that was exactly what it sounded like. A fan blade rubbing against a plastic shroud. Then it became a little more defined as grinding from the front wheel.
Maybe I have more than 1 issue. I will definately check.
Thanks
#2366923 - 09/04/11 11:58 AM Re: Grease Expedition axle behind front wheel bearing? [Re: Fitz98]
Trav Offline
Yes sure there could be more than one issue but it sounds like you got the problem figured out. Check it anyway for peace of mind.
OEM is the best but too darn expensive most of the time. Personally for aftermarket i really like SKF my second choice would be Timken then National.
