Fellers,
I have already stated that my cold inflation pressure was in-between 35 psi and 51 psi.
Here is what Capri Racer does say about sidewall stamped pressures on his web site...
http://www.barrystiretech.com/loadtables.html
Quoted from Capri Racer's own webpage, It states that:
Originally Posted By: Capri Racer/Barry's Tire Tech web page
I want to draw your attention to note #3 and the table that follows:
This note means that in spite of the load curve ending at 35 (or 41 for XL) psi, it is permissible to stamp the sidewall of the tire as having a maximum inflation of 35 psi, or 44 psi or 51 psi. (41 or 50 psi for XL).
If you were to dig to find the US regulation that covers what is supposed to be stamped on the sidewall of the tire (In this yearbook, it is FMVSS109, but this was superseded by FMVSS139 in 2007, but this part reads the same for both), the regulation is unclear which of those values it is supposed to be.
Most everyone in the tire industry reads the regulation that either 44 psi or 51 psi is the proper value for SL tires. However, a few tire manufacturers - notably the Michelin group (Michelin, Uniroyal, and Goodrich) have interpreted this differently and read the regulation to mean that for S and T speed rated tires, 35 psi should be stamped on the sidewall, while H and higher are supposed to read 44 or 51 psi.
That means for otherwise comparable tires, you will find different maximum pressures stamped on the sidewall. This means you SHOULD NOT use the pressure stamped on the sidewall as any sort of reference point, except, of course, what it says - a maximum.
and there are a couple exceptions to that!!
Let me further narrow down my tuned psi on my vehicle, for you guys...
I am over 40psi, and under 50psi.
So what think ye?
Thanks, Jim
