Is there anyone here that works with central HVAC systems and can shed some light on an issue I'm having. I been involved in a conversation over at the Clublexus forms. It has been stated that R134a (and other refrigerants) use the same pressure no matter the cooling system (refrigerators, automotive A/C, central A/C). However the pressure charts that he pulled out are far different than every source I can find for low and high side pressure in cars. He says that on a 90 degree day, high side pressure should be around 100-115 psi, but all my sources and the factory service manual for my Lexus GS300 says it should be 200-215. Does anyone know for sure if automotive A/C systems are higher pressure for the same type of refrigerant? If so, can you site a source?
Please keep in mind that this question assumes that a central system is using R134a.
