Originally Posted By: urchin
ARCO:
Are you for real??
My question is have you done anything with the coolant system on your own. eg replaced the coolant, added anything to it, ect.
As far as bubbles if you didn't do any work to the coolant system they should not be there. Did you check to make sure the cap is on correctly and that it is not faulty. See if you can try another cap.
Sorry to have to say this BUT the car is new and under factory warranty..stop playing with it and take it to a dealer that you have some trust in. Drive a bit out of the way if that will get you to a store that you have trust in.
Let the dealer check it out. If nothing else they can document what you are seeing so that if there is an early failure they will repair it in good faith even if the warranty is expired.
Bottom line get stuff like this documented in writing on your end and their end, these notation needs to go into the dealer RO system.
X2. If the described problems are very noticeable and not just automotive hypochondria, you need to take it to the dealer.
Rangers DO lose coolant..out the top of the reservoir. That's just due to the fact that the cap's design is based on that of a Tums bottle. Everything else sounds abnormal.
Does the "mechanical hard knock" sound like it's from the engine block, head, etc? Could be nothing, could be something...hard to tell if the noise isn't present at idle so you can track the noise. Many Fords do have some pinging, and Rangers are not the quietest vehicles out there. AC clutches on them tend to be pretty loud when they engage/disengage and could sound like a "knock." Any noises will be even louder if the truck doesn't have underhood insulation (my XL four banger didn't, XLT V6 does).
