Subaru Impreza 2.5i 5-speed manual
WIX Oil & Air Filters + FilterMAG
Background: I mailed in this sample to test the durability of Pennzoil Ultra and to determine if I had an internal headgasket leak. I noticed a wetness under the block on the driver's side that appeared to be a coolant/oil mixture. The car has never leaked or lost engine oil or coolant since I bought it new. Up until this UOA, I had always run Valvoline Synpower 5W30.
Blackstone Comments: Thanks for taking the time to speak with me on the phone. Back in 2008, Valvoline Synpower didn't have sodium, but we have a virgin sample from April of this year which does. That means that most (if not all) of the sodium we are seeing here is residual additive. Since you've seen some evidence of a coolant leak, we'll leave a ? there for now, but with wear looking this good, we don't think much antifreeze has gotten into the oil. The TBN is great, at 5.8, so this oil can go longer. Keep an eye on your coolant level, and check back at 7,000 miles. Nice!
Code:
OIL Penn Ultra 5W30 Synpower 5W30
MILES IN USE 5,000 5000
MILES 89,796 15,000
SAMPLE TAKEN 08/24/11 03/15/08
ALUMINUM 3 2
CHROMIUM 0 1
IRON 5 5
COPPER 4 2
LEAD 0 0
TIN 3 0
MOLYBDENUM 42 3
NICKEL 0 0
MANGANESE 0 0
SILVER 0 0
TITANIUM 0 0
POTASSIUM 3 3
BORON 275 8
SILICON 11 5
SODIUM 161 5
CALCIUM 2721 2296
MAGNESIUM 11 7
PHOSPHORUS 655 672
ZINC 738 816
BARIUM 0 2
Visc @ 210F 57.3 58.5
cSt Visc 100C 9.44 9.78
FLashpoint 410F 405F
Fuel %
Antifreeze ? 0.0
Water % 0.0 0.0
Insolubles % 0.3 0.4
TBN 5.8 3.2
So what I can gather is this appears to be nothing serious at all. To make my day even better Blackstone called me and talked to me about the report before issuing it, which is just going above and beyond what I expect for a UOA. I will retest my oil in another interval to see if the sodium drops.
Also, I'm extremely impressed with the durability of this oil. I didn't just commute on this oil, this car went up and down the tail of the dragon several times and was driven hard around the mountains during this interval. I can't believe the great wear and incredible 5.8 TBN. It might just convince me to go 7-10K per OCI from now on.
Also, I have changed the coolant for more genuine subaru green long-life coolant and I used 2 bottles of the conditioner just in case this is an early headgasket weep.
Code:
MILES 89,796 15,000
ALUMINUM 3 2
CHROMIUM 0 1
IRON 5 5
COPPER 4 2
LEAD 0 0
TIN 3 0
MOLYBDENUM 42 3
NICKEL 0 0
MANGANESE 0 0
SILVER 0 0
TITANIUM 0 0
POTASSIUM 3 3
BORON 275 8
SILICON 11 5
SODIUM 161 5
CALCIUM 2721 2296
MAGNESIUM 11 7
PHOSPHORUS 655 672
ZINC 738 816
BARIUM 0 2
Fuel %
Antifreeze ? 0.0
Water % 0.0 0.0
TBN 5.8 3.2
