Originally Posted By: kasedian
OK. I've decided to do a tranny fluid exchange on my 08 Silverado. Has 55K miles on it. It also has the factory transmission cooler on it. I'm goin to do the "poor man's flush" on it, meaning I'll pull the return line off of the cooler, put a fitting on the cooler, and run a hose from the fitting to a bucket. Anyways, I pulled off the line on the tranny cooler, and can't figure out what the thread pitch or type is on the cooler. Does anyone know, for a fact, what the thread pitch/type/size is? I went to the local farm & ranch store, Autozone, and even the GM dealer, and no can help me. Hopefully someone here has the answer. Thanks.
Does the old one thread in with a gasket or tapered (NPT). If it uses a gasket then its probably metric, but if its tapered then its probably NPT, but I also think there is a metric pipe thread, but its rare.
Are we talking rubber lines or metal? The pressure is pretty low, maybe you could push in a plastic line with the right OD. Or the other end of the line you disconnected.
Here is post for an older Silverado. The fitting to me does not look tapered. But things could have changed.
http://gmfullsize.com/forum/showthread.php?t=179148
Contact this place and ask
http://www.amazon.com/gp/search/ref=sr_ex_n_1?me=A293LVN2FWVDTC&rh=i%3Amerchant-items%2Cn%3A%2115690151&bbn=15690151&ie=UTF8&qid=1314668510
