I've got an 08 Chevy Express 3500 van. It has tire pressure monitors in each wheel. I just put new tires on the van today, and the monitors are now not on the correct wheels. I've got the recommended 50psi pressure in the front tires, and 80 in the rears. I verified this with an accurate gauge. The problem is that one of the wheels was previously on the rear and has been moved to the front, and vice versa. So I'm getting a warning that one tire on each end is low. It is showing the correct pressure for each tire, but because the sensor is in the wrong position, I'm getting the warning.
How do you set the tire pressure monitors for the right position? I assume this can be done, otherwise, how the heck can you rotate tires without changing the position of the sensors?
Any help with this would be appreciated. ( hope I explained this well enough to be understood correctly.)
