I have a 1965 Cessna 172F with a Continental O300-D
A lot has changed since that engine was designed and the manual written.
I did some initial reading and settled on Exxon Elite oil rather than Aeroshell.
However, with all the specialty formulated oils out there today, synthetics, etc. I wondered if there were oils that might be as good and cheaper or better and the same price.
For instance, I use Mobile 1 Fully Synthetic V-Twin 20X-50 for my air cooled motorcycle engines. This oil might be superior to Exxon Elite.
I am hoping to get some good advice from an oil expert.
Problems with the Continental O300-D engine in general include lead fouling from 100LL resulting in stuck valves, oil consumption (most use about a quart every 3 to 6 hours), some run hot during climb at full power, etc.
Since these engines require 8 quarts of oil, burn oil (as about any air cooled engine running WOT will do), and oil is replaced every 50 hours (not to mention basically a full change between as a result replacing 1 quart every 4 to 6 hours) I would like to reduce the operating cost by finding a lower cost oil but not at the expense of the engine.
Thanks for any advice
