Originally Posted By: Oregoonian
But I still think the MC filters are nor made for long OCI's. If I ever used one, I would not push them beyond 6K or so....never 10K. What are your thoughts ?
_______________________________________________
03' Ford Focus (2.3L Duratec PZEV) / 99K
PP 5w20 / Puro PureOne PA 10241 / OCI: 8K +/-
It's fine for a 10K OCI on a clean engine (the 820S, at least). The 820S filter is 80% efficient@ 20u and the capacity is 8 grams. The Ford Racing 820S is 99% efficient@ 20u and the capacity is 10.9 grams. So, when you consider the extra filtration efficiency of the racing filter, it's probably a wash as far as which one of those will handle more mileage. When I cut my 820 Racing filter open at 10K, it looked like it had been on for 1K miles. I have no doubt I could have done 15-20K without problem. But again, my engine is really clean, and I do a lot of highway miles, so the filter doesn't really see a hard life.
If anything, I think you're better off using the 820S for a longer OCI, since the efficiency will improve as it's on there longer--as long as the above caveats apply.
