Does your car have heated seats??? If so, then this bulletin may be your answer:
Service Information
2007 Chevrolet Impala | Impala, Monte Carlo VIN W Service Manual | Bulletins By Category | Technical | Document ID: 2399812
#10-08-50-001: No Crank, No Start, Discharged or Low Battery (Reprogram Heated Seat Module) - (Feb 15, 2010)
Subject: No Crank, No Start, Discharged or Low Battery (Reprogram Heated Seat Module)
Models: 2006-2010 Chevrolet Impala
2007-2009 Chevrolet Equinox
2007-2009 Pontiac Torrent
Equipped with Front Heated Seats
Condition
Some customers may comment on a no crank, no start, discharged or low battery.
Note: This condition may be intermittent, therefore it is important to check if a revised calibration has been released on TIS2WEB for this concern, even if the condition cannot be duplicated at the dealer.
Cause
This condition may be caused by the heated seat module discharging the battery. The module keeps the serial data bus active, which creates a cumulative, continuous amperage draw on the battery after the vehicle is shut down, until the state of charge reaches three volts.
Correction
Important: DO NOT replace the heated seat module or the battery for this concern.
Reprogram the heated seat module with the latest software calibration.
Important: Select the correct calibration files for the appropriate vehicle configuration (body style) and RPO codes.
A revised calibration has been developed to address this condition. Technicians are to reprogram the heated seat module using the Service Programming System (SPS) with the latest software available on TIS2WEB. Refer to the Service Programming System (SPS) procedures in SI.
When using a Tech 2® or a Multiple Diagnostic Interface (MDI) for reprogramming, ensure that it is updated with the latest software version.
During programming, the battery voltage must be maintained within the proper range of 12-15 Volts. Only use the approved Midtronics® PSC 550 Battery Maintainer (SPS Programming Support Tool EL-49642) or equivalent during programming.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
N9631*
Heated Seat Module Reprogramming with SPS
0.4 hr
*This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2011 General Motors. All rights reserved.
