Originally Posted By: BrianL
Originally Posted By: boxcartommie22
go5 going away..ford stopped using it...leaves deposits..they have gone to the orange universal stuff...final charge hd is the best...has no nitrites,boates,silicates, and phosphates...its in all their new vehicles...i trashed all the g05 in my vehicles and put in final charge.you can get final charge by peak at pep boys...also there is clear choice same coolant..google them both.
Does anyone else agree to any truth in this?
I've been putting off changing out the coolant in my 2004 Civic and thought I'd go with G-05 but now I'm hesitant.
So if avoiding Honda coolant, what should I use? Zerex G05, Zerex Asian, PEAK Global, Beck Arnley Extended Life, Final Charge HD?
Are some of these the exact same formula?
The truth is you'll likely have zero issues with any of the coolants that you mentioned if serviced within their useful lifespan.
If you don't mind spending the money and ordering, the Beck Arnley blue may be your best (closest) bet outside of going to the dealer.
Unfortunately the blue is premixed though. I was hoping to do a complete change, rather than a drain and fill, so I would end up with more water than coolant.
If there's not any signs of problems, I'd just do a couple of drain and fills. That blue stuff is some long lived coolant. 2 or 3 drain/fills will easily get you to where you need to be.
