Looking for info on two quick spray waxes.........
by demarpaint
05/01/16 04:43 AM
The Heroin Epidemic In The U.S....
by qwerty1234
05/01/16 01:28 AM
Air filter wrap
by Duffyjr
04/30/16 10:21 PM
15W-40 Delo, Delvac or Rotella For KUBOTA turbo
by pburchett
04/30/16 09:50 PM
Traveler synthetic oil a slow seller?
by Electromotive
04/30/16 09:34 PM
Tyre rubber, methanol, and bore wear
by Shannow
04/30/16 09:34 PM
What to use in 99 Buick Lesabre OCI?
by Duffyjr
04/30/16 09:26 PM
Help w/Transmission Drain/Fill 08 Honda CR-V 4wd
by klt1986
04/30/16 08:58 PM
pennzoil ultra platinum pure plus
by Brayden
04/30/16 08:10 PM
Group 5 synthetic oil
by Brayden
04/30/16 08:07 PM
Pennzoil Ultra platinum at Walmart
by RubentheIowan
04/30/16 08:03 PM
G-05 Change intervals, 3 or 5 years?
by Canadastang
04/30/16 08:03 PM
Doxxy, Jetstreamz06, TalNum, Spinnizle, JustinL
57758 Registered Users
16 registered (Bookmaker, eddy21, bmod305, billt460, FFeng7, 1 invisible), 620 Guests and 119 Spiders online.
57758 Members
66 Forums
248282 Topics
Page 1 of 2 1 2 >
#2341872 - 08/09/11 10:42 AM Felpro valve cover gaskets
Greenz Offline
Loc: Maryland
hello all,
I began purchasing parts to have my timing belt replaced for my '02 Mazda Protege. I decided to get the gates kit over the Dayco kit. The water pump and oil seals from Mazda, and vc gasket is felpro permadry.{on mazda forum site it was mentioned several times, but no specific reason as to why}
My question is what exactly is meant by permadry? Does this mean you dont need RTV for the gasket? Also why is felpro permadry the best to use?
thank you for any information you can provide
#2341883 - 08/09/11 10:53 AM Re: Felpro valve cover gaskets [Re: Greenz]
Cressida Offline
Loc: Joplin
Follow the instructions that comes with the gasket. If you need RTV it will come with the gasket - don't use it unless the instructions tell you to!
#2341898 - 08/09/11 11:11 AM Re: Felpro valve cover gaskets [Re: Greenz]
Greenz Offline
Loc: Maryland
it didn't come with instructions so I can't really say for sure. I'm really trying to figure out what is meant by permadry? Should I conclude that it goes on dry, and gives apermanent seal hence the name permadry?
Edited by Greenz (08/09/11 11:13 AM)
#2341916 - 08/09/11 11:25 AM Re: Felpro valve cover gaskets [Re: Greenz]
SteveSRT8 Online   content
Loc: Sunny Florida
Per Fel Pro they are intended to be used dry.
They are arguably the best out there, we use them a lot. Note that most are reuseable.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#2341937 - 08/09/11 11:43 AM Re: Felpro valve cover gaskets [Re: Greenz]
doitmyself Offline
Loc: MI
I agree with SteveSRT8's answer. Fel Pro seems to be adamant about not using gasket dressings of any sort.
Yet, Permatex markets gasket dressings and even says their RTV can be used as a gasket dressing (some say it allows the gasket to slip/slide out of place).
Amongst pros and diy'ers, there also seems to be 2 camps...3 if you count the ones that recommend just a dab on the corners to hold it in place during assembly.
This kills me.....I want black or white, not gray!!!!
"There are things you do that put food on the table, and there are things you do that feed your soul." I am blessed to have them be the same things.
#2341948 - 08/09/11 11:53 AM Re: Felpro valve cover gaskets [Re: Greenz]
Loc: Sunny Florida
In our extensive engine repair experience we have found that if the parts fit properly there is seldom any sealant needed.
If they fit poorly you are risking failure. Even with goo.
Always follow the gasket makers instructions or you may find yourself repeating...
#2341957 - 08/09/11 11:58 AM Re: Felpro valve cover gaskets [Re: Greenz]
Greenz Offline
Loc: Maryland
Thank you SteveSRT8, for clearing that up for me. Cressida and doitmyself thank you for input also.
#2341969 - 08/09/11 12:10 PM Re: Felpro valve cover gaskets [Re: Greenz]
qdeezie Offline
Loc: Charlotte, NC
The way I do it, is if it's a gasket for a flat surface as some valve covers are, I won't use RTV, but if it's a gasket that has a round or angular fit at the front or rear such as some OHC valve covers or oil pans, I use RTV in the corners of the gasket to account for surface imperfections, even if it is permaseal.
'90 F150 XLT Lariat | PU 5w-30 & RP Filter
'13 Hyundai Elantra Coupe SE | PU 5w-20 & OEM Filter
'03 Ford Focus ZX3 | Conv. Shell 5w-20 & OEM Filter
#2341986 - 08/09/11 12:22 PM Re: Felpro valve cover gaskets [Re: Greenz]
doitmyself Offline
Loc: MI
Oh, I forgot. Don't you think "permadry" is just their brand name for recognition, marketing, and spin? I don't think it has anything to do with use of gasket dressings.
#2342036 - 08/09/11 01:23 PM Re: Felpro valve cover gaskets [Re: Greenz]
morris Offline
Loc: ks, wichita
years ago my friend was a fel-pro rep. he said that fel-pro does not warranty valve cover gaskets that has had rtv on them. i like permatex #2. it sticks NOT slides. rtv slides cause its got silicon it.
#2342085 - 08/09/11 02:20 PM Re: Felpro valve cover gaskets [Re: Greenz]
Falcon_LS Offline
Loc: Kuwait
Fel-Pro is a Federal-Mogul brand, who are also suppliers to many OEMs. Their family of brands include names like Moog, Wagner and Champion.
The PermaDry name implies that the product is made of premium grade, molded rubber that takes the shape of the surface it seals without having to over tighten.
Their PermaDryPlus, on the other hand, is a premium "problem solver". It basically utilizes silicone rubber with an aluminum carrier to resist heat and pressure.
99 Explorer EB: GC 0W40/FL1A
00 Pajero: Aisin PAO/Ester 5W40/MD352626
01 Marquis: M1 0W40/FL820S
03 Expedition: M1 0W40/FL820S
05 Envoy: GC 0W40/M1206
#2342088 - 08/09/11 02:24 PM Re: Felpro valve cover gaskets [Re: Greenz]
Tempest Offline
Loc: Las Vegas NV
I recently put PermaDryPlus valve cover gaskets on my truck and they were very nice. Leak free so far.
They did call for some RTV at the corner junctions.
“Never underestimate the difficulty of changing false beliefs by facts.” --- Henry Rosovsky
#2342151 - 08/09/11 03:33 PM Re: Felpro valve cover gaskets [Re: Greenz]
mechtech2 Offline
Loc: Chicago Area
A little RTV at he corners and at the 1/2 moon seals is a good idea. Most factory cars use some there.
#2342288 - 08/09/11 05:40 PM Re: Felpro valve cover gaskets [Re: Greenz]
38sho Offline
Loc: North Palm Beach
I always RTV spots around cam caps where you have a 90 degree spot or if its a timing chain engine where the timing cover bolts to block, I'll put a little bit there at that seam, especially on oil pan gaskets....
93 Taurus SHO
Mobil 1 0w-40 and M-301 oil filter
#2342508 - 08/09/11 09:17 PM Re: Felpro valve cover gaskets [Re: qdeezie]
The_Eric Offline
Loc: Iowa
Agreed on the bold. Even OEMs do it. I also use a sparing dab at intersections, like say timing cover to block or rear main housing to block. If you don't it will leak or be more likely to leak because the gasket can't seal where that very narrow line is. Often times the paper gasket is sunk down just a touch and oil will flow through. Our shop learned that hard way on a Ford 3 valve 5.4 pickup. We (another employee) replaced the phasers and timing chain/guides. When he re-assembled, he didn't put a small dab where the timing cover meets the head. Oil leaked at that point where the valve cover sits over them and we had an annoyed customer and we had to eat the repair bill. Those particular engines are a bugger to work on - the a/c lines run over the top of the valve covers...
But generally speaking, I agree with those who say not to use any sealer on the gaskets.
2001 Hyundai Elantra 2.0
1998 Chevy Malibu 2.4
1995 Pontiac Grand Am 3.1
1979 Ford F-150 351M
Page 1 of 2 1 2 >
