Originally Posted By: gordonm
More questions:
In various online 'oil filter comparisons' I have read, the bypass valve location shown in the cutaway views of the Bosch filters is considered inferior to valves located at the baseplate end of the filter. The theory is, with the valve located as shown, oil will 'wash' over the filter media when the bypass valve operates, picking up contaminants trapped on the surface of the media and returning them through the bypass valve to the oil pan.
I'm wondering if someone can address this. Is this a valid concern? There must be some other advantage to the construction shown in Bob's post that I'm not seeing. Perhaps it's less complex/cheaper from a manufacturing standpoint; perhaps it allows the use of more filter media.
Another point: In the SHO oil filter article (don't have a link handy), the author claimed that this type of construction did not meed Ford specifications. Is this true? Do any other manufacturers spec filters with baseplate-mounted bypass valves only?
Yes, Ford specifications require the pressure relief valve to be on the threaded end of the filter. In the winter time, bypass valves will almost always open upon starting when the engine/oil is cold. Also since it takes an engine longer to reach peak oil temperature when the ambient temperature is cold (~less than 40F), the filter is more likely to go into bypass when accelerating.
As for whether it makes a difference in wear rates, you first have to believe that an engine ingesting a load of contaminents accelerates wear and bypassing at the dome end does this. If you study the dome area of a used cut-open oil filter (your own or from pictures posted in the oil forum), most often you will see specs/debris with the naked eye. What is more important is what you can't see; the contaminents in the sub 20 micron range. Ford claims that this is where the real wear causing particles reside and calls it sludge (oil mixed with organic and inorganic wear causing particles). Engineers claim that bypassing dirty oil during cold engine start-up is part of the accelerated wear that comes from cold starting.
As far as diminished wear from higher filter efficiencies, there is a decrease in wear but it is insignificant (ie, going from 90%+ to 99% @ 20 microns). I don't have exact numbers or references for what I am saying, just speaking from my work experience at SWRI. The focus seems to be not on SPFE but rather MPFE, where oil filter bench testing better simulates the real world.
In practice, several major automotive manufacturers have the pressure relief valve on the dome end for their OEM oil filter, but it does not seem to make a difference. I guess the same could be said about higher efficiency filters.
Speaking only about Ford, in my opinion it is better to go with the OEM filter (Motorcraft). Especially, where Ford uses a high volume oil pump (new cars/trucks with VCT).
