Guys,
I just got a 1968 Beetle from my dad that my daughter is going to drive. I've never messed with Beetles before so I have a few questions.
1) Should I clean the screen every time I change the oil or can I just drain the oil out and maybe clean the screen every other time?
2) How often should I change the oil? It is going to be in-town only and maybe 2K miles per year.
3) I noticed that it has some sort of aftermarket air cleaner on it instead of the original oil air filter (or whatever it is called). My dad says he has the original. Which is better? Should I convert back to the original? Or should I stick with the aftermarket thing? It looks like a conventional air filter.
4) I noticed that the ignition sticks. Meaning, when I start it, it wants to keep "starting" the engine. I have to back it off myself. Any suggestions on lubing/fixing this?
5) Are there any "gotchas" on these older Beetles? Anything I should look out for?
Thanks in advance!
Thanks in advance!
