Hey, quick question, i did a pan drop on the ciera, replaced the filter & gasket, reinstalled, filled with 6 qts of Castro HM ATF fluid, only to notice the transmission pan magnet was left out... How could i forget to put it back in the pan after cleaning everything up? I dont know..
Is it needed for say a 20K max mile OCI? That should be less then 6 months.. on the next change i will put it back in, or should i drop the pan, and reinstall it now? Its a small little magnet, pretty strong though, about the size of a oil change sticker..
Thanks!.
Thanks!.
