Originally Posted By: KenO
You couldn't pay me to own DexCool in ANYTHING. I've seen far too many failures (eaten-away water pump impellers for one), and I'm willing to bet a huge chunk of money that DexCool is the root cause of the intake manifold gasket failures. If I owned a car with DexCool I'd flush it out immediately and replace with a traditional Ethelyne Glycol anti-freeze like Peak LL or G-05.
DexCool doesn't eat water pump impellers. Cavitation does. What causes cavitation? Poor impeller design, flow restrictions, insufficient cooling system pressure (bad rad cap) and low coolant levels are a few to start with. Coincidentally low coolant levels and bad rad caps are a very bad thing to have in a DexCool system and will cause the sludge so many crow and caw about.
As for the IMG failures that have plagued GM, it happens in the old green systems too. I've replaced just as many, if not more IMGs in green filled systems as DexCool filled systems. Heck, even my wife's car needed them replaced and it's always taken care of. However, I will say that I'm pretty sure that there is a certain incompatibility with the 2EHA in Dex and some of the gasket frames.
Originally Posted By: Silver_civic
Good morning SteveSrt8, and thank you for the compliment. Yes gentlemen, at my work which is a fleet where we have VW, Volvo, GM, FORD, FIAT, CHRYSLER, HONDA, NISSAN, a few Mercedes, etc we have used the Khameleon anti freeze. No problems either. My friend who is older and been a mechanic for over 34 yrs has always owned gm vehicles says he has never had a problem when using the dex cool also. He told me that its used in GM's because he researched and found that the green anti freeze would etch aluminum and possibly eat into it. When I did a cylinder head job on a 09' cobalt a while ago, that vehicle got a flush of its anti freeze and Safety Kleen Khameleon put into it with a new thermostat and clean out of the overflow bottle. No problems afterwards I should mention.
This I believe. I've been into a few cars that were filled with green and around the port openings (at IMG), there was heavy pitting along with this white/tan gunk. Now mind you, this was in a very poorly maintained car and it was likely the factory fill, making it 15+ years old, but I think that's partly the reasoning behind GM's decision to switch to a long life coolant.
