Pretty soon here I'm going to replace the oil pan gasket on the F100, which has a 390. While I'm in there, I'm going to swap out the oil pump and screen. AFAIK, the motor is original and the internals are stock for sure.
I noticed at the auto store, they have standard and high volume. Any benefit to HV? I don't mind either way, just don't want a HV if it isn't really "better" to use. The differnce is $10 for what it's worth.
Reasoning for changing oil pump is also because of low oil pressure and it's quite cheap. I believe the low pressure is due to the lifters actually, but because of the price I'll change the pump/screen too. Labor is nil, so that's nice.
