Originally Posted By: barlowc
Originally Posted By: sayjac
the fact Nissan had to replace the exhaust manifold and cat under warranty might seem to indicate otherwise
Well, keep in mind that this is what one particular dealer decided to do and I bet they got paid a pretty penny (by Nissan) to do it. Dealers don't necessarily replace things because that's what is necessary and what Nissan itself says to do. They do it because Nissan will pay for it and it puts more money in the dealer's pocket.
The fact that this dealer replaced these parts indicates 'to me' that they obviously believed/ascertained there to be some failure/defect in one or both those two parts. One would think there would be some basis, ie., history, internal TSB, etc., to 'start' with that parts replacement. IMO, not a minor parts replacement for a CEL in a relatively low mileage vehicle, way more than just replacing an O2 sensor or two. As I said, I'm not sure they they know the real issue or how to fix it, and the fact that the O2 sensors regularly now fail, seems to bare that out. But, starting with two major parts on a low miles vehicle wouldn't be good, imo. Also, the OP is not sure of the original code/codes that led to the replacement, which would be more illuminating. But yes, I'm certain Nissan paid for it, not the dealer.
After thinking some, eljefino has brought up a good point. As the OP's vehicle threw a CEL, Nissan is liable to replace these parts likely under the extended emission warranty which would be difficult to get around. Also, that is a difference between the OP's vehicle and and all the 02-03 2.5L Nissans which didn't throw a CEL code until it was too late, generally out of warranty, and the engine fried. Except for spirited SpecV drivers who ended up with a new engine under warranty, whether the precat defect was also fixed is very doubtful.
This sounds to me like another Nissan 2.5L engine with exhaust manifold/precat/catalytic converter system defect.
