Hi guys, I'm wondering what it takes to create a good colloidal suspension with MOS2 and/or hBN. Obviously the smaller the MOS2/hBN the better but at what size does one start to see MOS2/hBN fall out of solution. Is it as simple as simply adding the dry MOS2/hBN to a base oil or do you need a catalyst (heat/binder/etc.) in order to maintain the suspension in a homogeneous/mostly-homogeneous state?
Has anyone ever tired running an oil + DI pack through a centrifuge? If not I'll do it when school starts up again next month.
I tried searching for this as I'm sure it's been covered already but I couldn't find anything.
