Hi everyone. I'm driving a Renault Laguna I, and the manual states that the correct power steering fluid is ELF RENAULT MATIC D2 or MOBIL ATF 220.
The Haynes Manual for this model states "ELF RENAULT MATIC D2, DEXRON II ATF"...
I just bough some Fluid to top off my reservoir, whose instructions state is it compatible with Dexron I and Dexron II specs.
Is it safe to use it? After a bit of googling it seems that both the ELF and MOBIL fluids are Dexron II TYPE D (whatever the D means, not sure), whereas the fluid I bought makes no mention of TYPE D, it just says it is compatible with dexron I and II.
Thanks for any help
Thanks for any help
