JHZR2
Staff member
Hi,
Im changing over to rotella in my 82 MB diesel, and so picked up some sae 30 rotella because it is cheaper and I wanted to try a single grade lube.
My temp/viscosity chart looks like this:
So you can see the range for sae 30, and also when running 40 is applicable. FYI summertime startup temp viscosities are as follows:
Rotella 15w-40 is 120 cst at 40C
Rotella SAE 30 and 40 are 107 and 120 respectively.
Rotella 5w-40 is 87.
So while a 5w-40 will pump a bit faster, the others will all flow roughly the same at startup in a heat wave, it seems to me.
But since the sae30 is rated up indefinitely in the chart shown, and sae40 has been blessed for use over 30C, is there a practical temperature limit beyond 30C to run sae30, and beyond which 40wt really is the lube of choice?
Any insight would be appreciated.
Thanks!
Thanks!
