I have a 01 Chevy Silverado (I’m the original owner) 2wd 4.8 liter auto. I have 94,000 on it (Low mileage due to buying a Honda civic for daily 81 mile commute 3.5 years ago. 18 mpg vs 40 mpg? Well, you know which one I drive the most now.). I maintain my vehicles well and normally don’t get rid of them until after they hit the 150,000 mile mark.
So I just got back from this trip from San Diego County up Hwy 395 into the eastern Sierras (As far north as Mono Lake). After getting my first refuel at Lone Pine (now a full tank, purchased at Mobil, where I get most of my gas) and heading back onto 395, all of a sudden, my low fuel light went on and my fuel indicator moved to E. It stayed there for about 10 seconds (As I started pulling over to the side of the road, think I might have somehow cut my fuel line) and then reset itself. So I started down the roadway again and about 10 minutes later, it did the same think. I pulled over in the rest area and disconnected the battery, waited for a few minutes (I’m think something in the computer needs resetting because of the elevation, maybe), reconnected, and no more problems for the rest of the day. Next day, problem started again, and today, same problem (And no I did not disconnect the battery).
At no time, when the low fuel light and indicator needle fell to E did I experience any hesitation (like running out of gas). Truck performed normally.
Before I take it down to the dealer to get checked out, has anyone else experience this problem before and if so, what was the cause?
I’m thinking it could be a solenoid or a relay going out. What about a sign that the fuel pump is on its way out? I have the original pump (I Had an 85 S-10 Blazer in which the fuel pump went out at the 75,000 and 150,000 mile marks).
Thanks for your help.
