Hi everyone.
I'd like to share what has happened to my "new" car in the oil consumption department
I bought it used. It had around 150.000 km (90.000 or so miles) and 13 years of age.
It's a Renault Laguna I, 1.8 liter, gasoline, similar to this one: Image
I made the first oil and filter change when I bought it, using SHELL HELIX HX7 10W40. In 10.000 kilometers, I had to add around 4 liters of oil to maintain the oil level.
I was starting to get scared at this oil binge, but recently, and after I changed oil and filter again, this time using BP VISCO 5000 10W40, it seems I no longer have to add oil to maintain the proper level.
As a side note, it seems that the car was stopped for a bit, befoe I bought it. It probably made less than 15.000 km (9.000 miles) in the last 4 years. But in this last year, since I've bought it, I've made around 15.000 km (9.000 mile).
Another side note is that the car manual requires an API SH or better oil. The SHELL HELIX is an API SM, whereas the BP VISCO is an API SL.
I was just wondering if this "oil binging" reduction has any plausible cause. Could it be because the car had little use for a while? Was it the oil I used on this second change?
Any ideas?
Any ideas?
