So, the Civic has had it's outer CV joints at each wheel making some noise now for 2-3 months.
The shop I had replace the original CVs 16 months ago now, claims that it's not noisy enough to get the part(a reman) warrantied/replaced by the manufacturer and wants me to drive it longer(until its out of warranty apparently? lol). The symptoms of driving the car are starting to annoy me though, along with a drop in fuel efficiency(40+MPG easily down to 35-36).
It almost feels like a drag on the engine, like driving with a partially applied park brake/or slight brake pad drag of some sort. The car seems to be lugged/sluggish upon acceleration and engine braking while in gear is excessive compared to when the CVs functioned properly, the rolling distance has been shortened and requires throttle sooner/more of it upon acceleration from coasting.
My question is would it affect MPG considerably? I figure it would some, as the MPG seems to be around what the car was getting prior to the original CVs being replaced.
I realize that A/C usage will give similar performance related drops(fuel economy, overall performance stop 'n go etc), but this feels like overkill compared to just running the A/C.
Along with that, is there any reman part manufacturers that are more reputable than others?
I can get an EMPI, A1/Select Cardone, and AUP; among others.
