I've already talked briefly to the Time Warner guy, and they are sending someone out on wednesday to fix it.
A few weeks ago I started having issues where the Cable modem (Motorola SB5101U) would start flashing "Send" at me for a few minutes, then "receive" for a minute, then send again. No internet, and unable to access the Modem's settings via 192.168.100.1. Called Time Warner and just as he answered, it started working. He checked the signal, and (I was able to get in now too), the Downstream is good,
Frequency 561000000 Hz
Signal To Noise Ratio 38.0 dB
Power Level -2.0 dBmV
But he said the upsteam power level was too high (no, it wasn't over 9000....)
Channel ID 7
Frequency 29900000 Hz
Power 55.0 dBmV
He says 55dBmV used to be the upper limit, but with more subscribers it's been lowered to 50.0dBmV. He says it's not too high to always cause issues, but it would be sporadic, which is what it's been.
Here is the logs from the modem as well
Time Priority Code Description
1970-01-01 00:00:22 3-Critical D003.0 DHCP FAILED - Requested Info not supported.
1970-01-01 00:00:15 3-Critical R002.0 No Ranging Response received - T3 time-out (US 7)
1970-01-01 00:00:07 6-Notice M571.1 Ethernet link up - ready to pass packets
1970-01-01 00:01:18 3-Critical D003.0 DHCP FAILED - Requested Info not supported.
1970-01-01 00:01:18 6-Notice M571.1 Ethernet link up - ready to pass packets
1970-01-01 00:01:03 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:00:09 6-Notice M571.4 Ethernet link dormant - not currently active
2011-07-19 00:48:15 6-Notice M573.0 Modem Is Shutting Down and Rebooting...
2011-07-19 00:48:15 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
2011-07-19 00:48:15 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:00:23 3-Critical D003.0 DHCP FAILED - Requested Info not supported.
1970-01-01 00:00:16 3-Critical R002.0 No Ranging Response received - T3 time-out (US 7)
1970-01-01 00:00:07 6-Notice M571.4 Ethernet link dormant - not currently active
2011-07-19 00:31:07 6-Notice M573.0 Modem Is Shutting Down and Rebooting...
2011-07-19 00:31:07 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
1970-01-01 00:24:52 3-Critical D003.0 DHCP FAILED - Requested Info not supported.
1970-01-01 00:24:44 3-Critical R002.0 No Ranging Response received - T3 time-out (US 7)
1970-01-01 00:24:34 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:24:08 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
1970-01-01 00:24:07 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:24:07 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
1970-01-01 00:22:56 3-Critical R002.0 No Ranging Response received - T3 time-out (US 8)
1970-01-01 00:22:49 3-Critical R002.0 No Ranging Response received - T3 time-out (US 12)
1970-01-01 00:22:39 3-Critical R002.0 No Ranging Response received - T3 time-out (US 11)
1970-01-01 00:22:27 3-Critical R002.0 No Ranging Response received - T3 time-out (US 10)
1970-01-01 00:22:21 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
1970-01-01 00:21:10 3-Critical R002.0 No Ranging Response received - T3 time-out (US 9)
1970-01-01 00:21:04 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
1970-01-01 00:19:49 3-Critical R002.0 No Ranging Response received - T3 time-out (US 7)
1970-01-01 00:19:38 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:18:57 3-Critical R002.0 No Ranging Response received - T3 time-out (US 10)
1970-01-01 00:18:52 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
1970-01-01 00:17:40 3-Critical R002.0 No Ranging Response received - T3 time-out (US 9)
1970-01-01 00:17:36 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
1970-01-01 00:16:25 3-Critical R002.0 No Ranging Response received - T3 time-out (US 8)
1970-01-01 00:16:17 3-Critical R002.0 No Ranging Response received - T3 time-out (US 12)
1970-01-01 00:16:06 3-Critical R002.0 No Ranging Response received - T3 time-out (US 11)
1970-01-01 00:16:00 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
1970-01-01 00:14:45 3-Critical R002.0 No Ranging Response received - T3 time-out (US 7)
1970-01-01 00:14:33 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
1970-01-01 00:14:33 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:14:23 3-Critical R002.0 No Ranging Response received - T3 time-out (US 12)
1970-01-01 00:14:14 3-Critical R002.0 No Ranging Response received - T3 time-out (US 11)
1970-01-01 00:14:02 3-Critical R002.0 No Ranging Response received - T3 time-out (US 10)
1970-01-01 00:13:57 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
1970-01-01 00:12:46 3-Critical R002.0 No Ranging Response received - T3 time-out (US 9)
1970-01-01 00:12:40 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
1970-01-01 00:11:29 3-Critical R002.0 No Ranging Response received - T3 time-out (US 8)
1970-01-01 00:11:24 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
1970-01-01 00:10:13 3-Critical R002.0 No Ranging Response received - T3 time-out (US 7)
1970-01-01 00:09:58 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:09:58 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
1970-01-01 00:09:55 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
1970-01-01 00:09:55 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:09:45 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
1970-01-01 00:09:44 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:09:33 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
1970-01-01 00:08:21 3-Critical R002.0 No Ranging Response received - T3 time-out (US 8)
1970-01-01 00:08:07 3-Critical R002.0 No Ranging Response received - T3 time-out (US 12)
1970-01-01 00:07:59 3-Critical R002.0 No Ranging Response received - T3 time-out (US 11)
1970-01-01 00:07:55 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
1970-01-01 00:06:44 3-Critical R002.0 No Ranging Response received - T3 time-out (US 9)
1970-01-01 00:06:33 3-Critical R002.0 No Ranging Response received - T3 time-out (US 10)
1970-01-01 00:06:28 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
1970-01-01 00:05:16 3-Critical R002.0 No Ranging Response received - T3 time-out (US 7)
1970-01-01 00:05:03 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:04:40 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
1970-01-01 00:04:39 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:04:38 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
1970-01-01 00:04:38 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:04:37 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:04:36 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
1970-01-01 00:03:25 3-Critical R002.0 No Ranging Response received - T3 time-out (US 8)
1970-01-01 00:03:14 3-Critical R002.0 No Ranging Response received - T3 time-out (US 12)
1970-01-01 00:03:03 3-Critical R002.0 No Ranging Response received - T3 time-out (US 11)
1970-01-01 00:02:55 3-Critical R002.0 No Ranging Response received - T3 time-out (US 10)
1970-01-01 00:02:50 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
1970-01-01 00:01:38 3-Critical R002.0 No Ranging Response received - T3 time-out (US 9)
1970-01-01 00:01:31 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
1970-01-01 00:00:18 3-Critical R002.0 No Ranging Response received - T3 time-out (US 7)
1970-01-01 00:16:00 3-Critical R002.0 No Ranging Response received - T3 time-out (US 12)
1970-01-01 00:15:54 3-Critical R002.0 No Ranging Response received - T3 time-out (US 11)
1970-01-01 00:15:47 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
1970-01-01 00:14:33 3-Critical R002.0 No Ranging Response received - T3 time-out (US 9)
1970-01-01 00:14:25 3-Critical R002.0 No Ranging Response received - T3 time-out (US 10)
1970-01-01 00:14:21 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
1970-01-01 00:13:08 3-Critical R002.0 No Ranging Response received - T3 time-out (US 7)
1970-01-01 00:12:56 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:12:18 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
1970-01-01 00:11:06 3-Critical R002.0 No Ranging Response received - T3 time-out (US 8)
1970-01-01 00:10:55 3-Critical R002.0 No Ranging Response received - T3 time-out (US 12)
1970-01-01 00:10:46 3-Critical R002.0 No Ranging Response received - T3 time-out (US 11)
1970-01-01 00:10:42 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
1970-01-01 00:09:28 3-Critical R002.0 No Ranging Response received - T3 time-out (US 9)
First of all, from what I understand the downstream power level is good, but the fact that the modem is trying to transmit at 55.0dBmV means that there is something wrong? What are they going to try to do to fix this?
And what does the stuff in the log mean? Some of it I understand, such as the DHCP stuff, and Ethernet link, but the other stuff is gibberish to me.
Channel ID 7
Power 55.0 dBmV
