Post your latest oil change
1999 Isuzu Rodeo LS
93,000 miles
Supertech 15W-40
Fram Extra Guard oil filter
Used this stuff because it was sitting around the garage for over 2 years and didn't want to waste it.
Brother 2000 F350 7.3 DRW 2WD
Out 6000mi Delvac 1300 and Stratapore filter
In- Delvac 1300 super and Stratapore Filter 177,000 on truck
Also installed my fuel system, HPX line and custom tow tune.
My 2000 F350 4WD 7.3 PSD
Out Redline 15-40 Stratapore filter FS2500 Bypass filter Element.
IN: Redline 15-40 Stratapore Filter and a new FS2500 Element. 20,000 OCI. 220k on truck, 38,000 on built engine
04 explorer 4.0
5 qts qsad SN 5/30 and a fl820s
04 f150 5.4
5 qts maxlife 5/30 SN 2 qts maxlife 5/30 SM
fl 820s
a little quieter than other oils i have tried in this truck, kinda like it.
2001 Tahoe 5.3 142,740 miles
Out: Mobil Clean 5000 10w-30 with PureONE filter. Ran it for 3,500 miles.
In: M1 0w-40 with PureONE filter
Got a great deal on the 0w-40 so I figure I would give it a try since a lot of BITOGers like it so much.
1996 Yukon 5.7
AC Delco PF52 and Shell Rotella T5 10-30
2005 Toyota Sienna
Purolator PureOne and Mobil 1 5W-30 High Mileage
1998 Contour V6
K&N filter and 1/2 Valvoline 5-40 Euro formula & 1/2 Valvoline Maxlife 5W-20 semi-synthetic.
2001.5 Nissan Pathfinder 3.5L VQ35DE, 125,908 miles
Out: Pennzoil Yellow Bottle 10W-40 / Purolator PureONE PL14610, used for 2745 miles
In: Mobil 1 High Mileage 10W-40 / Mobil 1 Extended Performance M1-110
2008 Chevy Malibu 2.2(brother's gf's car);
-5qts Maxlife 5w30
-Fram CH9018, cartridge type filter.
~90,000 miles.
2007 Ford Mustang V6(bro's car);
-5qts Platinum 5w30
-6 oz. LM Mos2
-MC FL820S filter
40,000 miles.
1991 Dodge Dynasty. 3.3 liter engine. 134805 miles.
2 qts. Castrol Edge Syn 5W/30
1 qt. Castrol Edge Syn 5W/20
2 qts. Mobil 1 5W/40
1 qt. Pennzoil 10/W30
Carquest 85515. That's why I needed the extra quart. The regular application, an 85085 is Element Dimensions: 3.79 height, 3.66 outer diameter, 3/4-16 inner diameter. Gasket Dimensions: Outer Diameter 2.834, Inner Diameter 2.462, Thickness .200. The 85515 is the same for the Gasket Dimensions, but the Element Dimensions are: 5.178 height, Outer Diameter 3.66, 3/4-16 Inner Diameter, the Height being the only difference.
