Originally Posted By: disturban
Do you guys think all the engine noise I am hearing could be because the Mobil 1 EP is a SN rated oil and does not have as much ZDDP as older oils and the 1995 4.0 is a flat tappet camshaft?
I think am going to add some Redline Engine Oil Break-In Additive to boost the ZDDP level and hope that will quiet things down?
ZDDP or any other additive won't quiet it down, they're good for wear, sure, but noise happens because of excessive bearing clearance, so increased viscosity might help.
What's your oil pressure at warm idle? If it's really low, like under 8 PSI, then your oil is too thin for this set of bearings.
If you really think it's a rod knock, then the motor is on its last legs (yeah, you can change rod bearings, even mains, but that's a stopgap measure at best because you're not able to mic the journals and know if they're worn or not). But lots of things can sound like a knock...
I would change the oil and filter ASAP, start with an HDEO like Rotella T 15W40 or the T6 if you're a synnthetic guy...see what happens to the noise then.
