Originally Posted By: The_Eric
Maybe U.S. based 5w-30, I doubt it's thicker than a Euro spec'ed ACEA A3 5w30 (HT/HS or 3.5cp)
I see. I didn't realize that it was ACEA A3. In that case, 3.5 cP is the minimum allowed fresh-oil HTHS viscosity. Perhaps it would shear down to near or below 3.0 cP with used oil.
In that case, you can't use most xW-30 oils with this car. You should either find an ACEA A3 xW-30 or use an xW-40 or thicker oil. They all have fresh-oil HTHS viscosity of 3.5 cP or higher.
In US a good substitute for the European ACEA A3 oils would be the API CJ-4/SM 5W-40 oils. While they are intended mainly for heavy-duty diesel engines, they should work very well in these high performance engines as well. Rotella T6 5W-40 CJ-4/SM fully synthetic oil for example would be a great and economical US substitute for ACEA A3 in my opinion. Note that Rotella T5 10W-30 CJ-4/SM semisynthetic oil also has HTHS viscosity >= 3.5 cP.
