Decent Wireless Computer Headset?
by 99Saturn
06/25/16 11:41 PM
Need Fuel Pump Assembly for Camry
by Nick1994
06/25/16 11:36 PM
2015 Accord V6 VCM engine UOA 36,680 mi / 9812 OCI
by TNM1982
06/25/16 10:55 PM
Why did Toyota recommend a winter and summer oil?
by BrianApp
06/25/16 10:00 PM
Fram TG 7317 6k miles
by bbhero
06/25/16 09:57 PM
Sta-Lube Moly-Graph Grease
by JHZR2
06/25/16 09:20 PM
Dead battery locks me out of Altima!
by Tom NJ
06/25/16 08:56 PM
Second lawn mower blade
by greasegunn
06/25/16 08:11 PM
Echo weed trimmer - carb issue?
by ryan2022
06/25/16 07:13 PM
Reviving Old Hard Rubber Experiment
by sleddriver
06/25/16 04:47 PM
Where do pets go?
by Whitewolf
06/25/16 04:47 PM
Help reading Bosch 3330 date code
by beavis87
06/25/16 04:11 PM
paul2005tb, Martyaus, carmelo, Shellman, SSO
58272 Registered Users
29 registered (2004tdigls, bdcardinal, 2015_PSD, asand1, Andy636, 6 invisible), 958 Guests and 11 Spiders online.
58272 Members
66 Forums
250818 Topics
#2313480 - 07/12/11 09:19 AM Converting Honda self propelled to push model
Jeepster_nut Offline
Loc: East Coast
I have tried (unsuccessfully) to sell my 6 year old HRR216SDA self propelled mower on CL. Any mention of transmission issues brings out the low ballers it would seem.
It has something amiss with the self propel feature. I haven't the time nor desire to dig in and trouble shoot or throw money at it to resolve the issue...
I have noticed that Honda sells the same model (rear discharge, bagger, mulch capable with the quadra cut blades) as a push only model. I am guessing that Honda just omits the rear axle/transmission, cable and engagement lever assembly.
In theory can't I simply remove these items from my model? The rear wheels don't bolt to the axle so they can function without it. The height adjustment won't be affected either. I would shed probably 5-7 lbs by doing so. What do you guys think?
For every complex problem there is a simple solution...and it is wrong. - H.L. Mencken
#2313528 - 07/12/11 10:15 AM Re: Converting Honda self propelled to push model [Re: Jeepster_nut]
mpvue Offline
Loc: Easton, PA
why not? if its broken WITH the 'feature', and you can't sell it as it, you have nothing to lose.
"I am preety smart guy 3.5 or higher in all my college class's and I have no clue any more".
-JohnBrowning
#2313538 - 07/12/11 10:22 AM Re: Converting Honda self propelled to push model [Re: Jeepster_nut]
Loc: East Coast
Should I advertise it as "used to be self propelled but converted to push" or simply sell it as a push mower without mention of having been previously self propelled?
#2313640 - 07/12/11 11:56 AM Re: Converting Honda self propelled to push model [Re: Jeepster_nut]
JTK Offline
Loc: Buffalo, NY
I'd have to pull a wheel off of mine to take a peek, but I believe all you'd have to do is remove the drive axle, or the small drive gears on the ends of the drive axle.
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#2315058 - 07/13/11 05:40 PM Re: Converting Honda self propelled to push model [Re: JTK]
01rangerxl Offline
Loc: Birmingham, AL
I'm pretty sure that JTK is right. Removing the wheel gears will disable the transmission and allow the wheels to move freely. Removing the transmission and other self-propel pieces will reduce weight a little. Take off any "Variable Speed" or other stickers, and most won't be able to tell. There will be a couple holes in the handle and deck and ring gears on the insides of the rear wheels, but no other visible differences. The wheel adjusters are the same part number for both models of mower.
I wouldn't disclose the removal of the transmission unless asked. It's probably not worth the hassle of trying to explain it to most people.
Edited by 01rangerxl (07/13/11 05:43 PM)
2002 Ford Ranger XLT | 3.0 V6 / 5-Speed Automatic / 2WD | 185K miles
1994 Ford Ranger STX | 4.0 V6 / 5-Speed Manual / 4X4 | 180K miles
