What ever you do, if you want to clean the engine up I would not use a straight conventional except to use it for short intervals with an oil additive.
Instead, consider 3,000 to be the LIMIT of sanity for your oil changes over the next year in this vehicle(or longer than a year). You have many options moving forward. You could use what is called Heavy Duty Engine Oil, run that for 2,500 mile oil change intervals, changing your oil filter half way and topping off the oil.
That's one idea, others have suggested what basically lead in the same direction by means of a different method. A good synthetic, frequent oil changes etc, especially should you consider using reliable yet cheap oil filters and changing them every 1,500 miles or less.
Kreen seems like it is a great additive, but personally I wouldn't go straight for additives, perhaps MMO to start and then work up to Kreen. If you have the ability to get this engine opened up once you get it back, get access to underneath the valve covers and drop the oil pan.
Manual cleaning, done in a well thought out manner, will greatly help you moving forward to getting a clean engine than simply short OCIs with any oil + any additive in consideration. Those should be 'post' clean up oil choices, even then sticking to 2-2.5k mile OCIs for the next year would be advisable after successful manual cleaning of the top-end and bottom-end.
