oil filter
alabama
I have a cub cadet with Kohler Courage 20,what oil filter can use instead of the KH-12-050-01 S1?
A quick google search reveals that a Wix 51056 is a direct replacement. I am sure that there are others as well.
Take your pick.....
AC-DELCO PF2210
BALDWIN B1410
BIG A 92056
CARQUEST 85056
DONALDSON P502051
DONALDSON P551763
FLEETGUARD LF16108
GENERAL MOTORS 25313748
HASTINGS LF302
JOHN DEERE KH1205008
KOHLER 12 050 01
KOHLER 12 050 01S
LUBER-FINER PH2814
MIGHTY PH2814
NAPA 1056
PUROLATOR L35310
VALVOLINE L3512
WARNER PH2814
WIX 51056
WIX 51056MP
WIX 51344
Thanks I had bought a couple of tune up kits at Tractor Supply last year on clearance for 2.99,now I need to do oil change but not wanting to pay price for Kohler filter
Personally, I use the Purolator filters. The Wix/NAPA filters are a great choice too. Usually these filters are longer than the stock ones, which is good, but, make sure you have room for them. I'm not too familiar with the Kohler engine setup.
Which Kohler Courage? The single cyl or the V-twin? You've got completely different possibilities between the two. The sky is basically the limit with the V-twin (same fitment as a Command twin), where the orientation of the Courage single cyl allows for only OEM sized filters.
I ran Motorcraft FL400's on my Courage 20 V-twin.
Joel
I would highly recommend the Motorcraft FL400 or x-ref or your choice then.
That's a fine engine you've got. People generally freak out when they hear "Courage Series", but the twins are a different animal than the singles.
Joel
