Hi,
I have a 2004 Nissan Xterra V6 2WD w/81K miles. Both head gaskets has small external leaks and needed replacing. Once heads were off I got a call from dealer saying the engine had oil sludge and best bet was a new $5,700 motor.
I mentioned how a motor with 81K can have sludge, let alone two bad head gaskets, and their answer was bad oil or long intervals between changes. The car has always had Castrol, Pennzoil or Chevron and I think the most I ever went between changes is 5,100. Most of them were in the 3-4k range.
I guess my question is, how bad does it look from these photos and am I screwed on this engine or can it be cleaned somewhat?
And if cleaned, what would be the suggestion? I was looking online at engine cleaners and the opinions are all over the place. If people agree that cleaners don't tear your engine up and/or are a waste of money, then they are arguing about brands. Then there is the kerosene and ATF crowd. And the use synthetic to flush it out crowd. Do any of these methods have merit? (For what it's worth, the garage I normally go to said if I wanted to do the cleaning they use Justice Bros., BG or LucasOil.)
Thank you for any advice.
