Many of us who own older Euros have used 15W-40 HDEOs and have recommended them to others.
I used Castrol Tection Extra 15W-40 for the current period last year in my old e36, while this year I've been using M1 EP 15W-50 in it, mainly because I had some and wanted to use it up.
I expected to take some hit in fuel economy, since the M1 is a thicker oil by every measure than the Tection.
The M1 EP has HTHS of 4.6, while Castrol does not deign to give this measure that I could find. The M1 is thicker at both 40C and 100C, according to the two PDSs.
In the nine hundred miles I've put on the car since last Tuesday, though, fuel economy appears to be slightly better.
I've actually averaged a little over 30 mpg, while I never bettered 29 mpg on the Tection.
My driving has been quite similar, including the same weekend trip on each oil on the same weekend in each year.
How could going up a grade not only not hurt fuel economy, but maybe even improve it?
The only thing that I can figure is that the M1 has a larger content of friction modifiers than the Tection.
The moral may be that you loose in fuel economy what you save in oil cost with a HDEO.
What experinces have others had with thick PCMOs vs HDEOs?
