I have been running 5w40 synthetic in my '03 vw jetta 2.0. Checked my oil yesterday and it was down a bit and added 3/4 of a quart of 5w20 synthetic by mistake.. Obviously should have done my research prior, but... What effects will this have on my engine? Did I screw up and need to get a full oil change? (I haven't driven anywhere since adding the oil)
Also, on a side note, is it overkill running synthetic in my jetta 2.0, or should I have just stuck with dino-oil?
Thank you in advance for your responses!
