Originally Posted By: DrDusty86
10w30 is well not spec'd for the modulars....you will cause more wear using 10w30's.
That is quite confusing, because back in 1991, 10W-30 was the default standard. For the 4.6, the internal running tolerances have not changed much, and I would imagine the same applies to the 6.8. Ford still recommends 10W-30 for Modular engines in the Middle East.
