I bought a 2003 S10 4.3L with 92-94K in Dec, and noticed lifter clatter at startup: warm and cold.
Took it to dealer who told me lifters were bad, and that truck probably had never had oil changed and had very bad sludge buildup.
So I had them change oil to synthetic, and changed the oil after about a month of 7-10 mile work and back commutes. During change ran an engine flush through and put in cheap dino oil (don't like leaving engine flush in oil cooler with good oil going in).
After a week, changed to Valvoline SynPower 0W-20. Also, started having lifter clatter with new lifters...
Ran the Valvoline for about 3k (lifter clatter stopped), then changed oil for move from FL to WA - chunks of congealed oil came out.
During the move (truck loaded and pulling 4x8' trailer, so getting a decent workout) oil pressure dropped from a healthy 30-40 psi to 18 psi at 2200 RPM freeway speeds.
At first I thought it might be OK, but oil pressure drops to 0 psi at idle - no lifter clatter so oil is getting to the topside, but no oil psi is creepy.
Truck also developed an oil leak an lost 1.5 quarts over the duration of the trip (I added cheap 5W-30 (recommended viscosity) dino oil). It's either rear main seal, oil cooler, cam plate, or balance shaft. (have to get under to further diag)
So, my question is: Where to go from here with cleaning sludge out?
I was thinking of adding a quart of ATF for a quick trip to the hand car wash (to degrease undercarriage...) then changing oil again.
Truck runs great (aside from various, umm, "ticks" from poor maintenance), and pulled great in overdrive (3.08s in a limited slip diff) over northern rockies in S. Dakota through WA.
Any advice??
Thanks!
Any advice??
Thanks!
