JHZR2
Staff member
Hi,
Ive read that the nominal rim diameter is not what you would measure if you checked out a wheel. For example, a 14" rin would actually measure closer to 15" and so on.
Is this the case? If so, how does one readuly verify the rim diameter to be correct if buying wheels?
Is there a standard "real" diameter for each wheel size?
Ive never measured, so I dont really know. Hope some experienced folks can verify...
Thanks!
Thanks!
