I put 25,000 miles on a Triumph Sprint 955. The owner's manual said EITHER 10W-40 or 15W-50 were "OK". I got curious enough to write Triumph engineering in England about the 10W-40 and received a reply saying it is FINE and "Commonly used". They had zero concerns.
I was not about to pay the rip off Dealer prices for the "special" Triumph Mobil 1. I used Mobil 1 10w-40 from Walmart and had zero problems and when the valve clearance was checked at 12K miles only ONE of the valves need a shim and it was "just barely" out of spec. All the foregoing is fact, not my "opinion".
I would bet you a TON of money that your bike will run "forever" with Rotella T 15W-40. Cold facts are that you probably will trade that bike LONG before you ever get even close to wearing it out. Unless you have aspirations of seeing 200K on that bike, "oil" is a "non-event" if you use a decent oil and change it at reasonable intervals. Rotella T, Delo 400 or Mobil Delvac all in 15W-40 all would seem to be an excellent and economical oil for your bike. If those oils will successfully stand up in Caterpillar diesel off road equipment running at full throttle for days at a time, KTM off road race bikes and many sport bikes, (which it DOES) it will be FINE in your Brit bike !!
If you really want to maximize "power", I would use the Mobil 1 motorcycle oil in 10W-40. (Or other premium synthetic 10W-40 bike oil) I and several friends have switched between it an various premium dino oils and you CAN tell a slight difference, especially in something like a GSX-R-1000 or other high rpm sport bike. You CAN feel a fractionally stronger pull, especially at high RPM. That is also not "opinion". That is based on oil "swaps" in Gixxer 1000's, RC-51's and a Honda VFR800. I confirmed that my Triumph triple also ran a couple of degrees cooler on the M-1.
Not enough to be significant, but the digital temp gauge did not lie.
Bottomline: there are a LOT of really excellent oils that will work very, very well in your bike. You just need to decide what is the deciding factor you want to optimize. One minor advantage to the 15W-40 dino oils is that they are significantly cheaper and you will feel a little less guilty about doing shorter oil change intervals.
