Hey there,
I have a 2008 Scion xB... And two years ago I took it to the dealer because my coolant level was below the "Low" level. They inspected for leaks, found nothing, and topped it off saying temperature/pressure cause level changes. Either way, it was at FULL when I left.
Two years later, it is not about one inch below the LOW level again. I called the dealer, and they basically told me if they don't find a leak they will charge me $80 regardless. If they do find something, it is covered under my warranty.
Thing is, I never seen a leak anywhere. And the leak is so slow, wherever it is, is it worth the trouble and possible $80?
Or do I just buy some fluid and top it off every six months or so? Very slow leak as you can see, but wonder what may cause it?
Thanks!
Thanks!
