I understand on wet and winter conditions that tire grip lessens considerably as tire wears down.
I noticed when I pushed my 2004 WRX with 80k around a sharp corner it squealed quite a bit under power. In the past it would not do this that I can recall with its newer RE960 tires that were installed on car at 30k miles.
Currently the RE960's are 6+ years old and have 3/32" tread left. They also have very small cracks at tread/sidewall edge.
Does dry traction also lop off as tread wear is gone too?
