USB flash drive security
by bowlofturtle
07/02/16 04:32 AM
Radiator fan motor on the way out?
by Falcon_LS
07/02/16 04:05 AM
Ultimate "el cheapo" oil change, LOL
by gfh77665
07/02/16 02:54 AM
Chrome polish for spoke wheels
by gman2304
07/02/16 01:52 AM
'09 Nissan Sentra-Eni i-Sint XL 4AM 5w-30-10k.
by montero1
07/02/16 01:11 AM
Questions about manual transmission sounds
by Why_Anything
07/01/16 11:09 PM
HOW to learn PINSTRIPING & lettering ??
by SumpChump
07/01/16 11:08 PM
'96 Nissan Maxima - Intake R&R - EGR tube bent
by 92saturnsl2
07/01/16 11:00 PM
Anybody want a lot of 6 Carquest Blue 84060?
by CapitalTruck
07/01/16 10:38 PM
new Tundra color
by lawnman
07/01/16 10:36 PM
Bought A Yamaha XSR900 today!
by donnyj08
07/01/16 10:21 PM
Akebono ProACT vs EBC Ultimax "Blackstuff" pads
by slacktide_bitog
07/01/16 10:08 PM
Aidil, dandandan, dbertheau, Jennyp, dcdodge
58341 Registered Users
25 registered (bernau, bigdreama, Black_Thunder, bdcardinal, bowlofturtle, 01_celica_gt, 2 invisible), 823 Guests and 11 Spiders online.
58341 Members
66 Forums
251133 Topics
Page 1 of 2 1 2 >
#2295770 - 06/23/11 12:36 PM Engine Blow By
chevman4life Offline
Loc: TX
Just curious but I heard a lot of people talk about "blow by" in an engine and I understand how it occurs, but what are ways to slow it down? I've heard people say to run 15w40 etc. What are ya'lls thoughts? Or a high Moly oil, which now what Dino oils are high in Moly?
1982 Chevy C10, 211k
1988 Buick Estate Wagon
2005 Ford Mustang V6, 132k, Amsoil 10W30
2010 Ram 1500 HEMI, 101k, Amsoil 0W30
#2295774 - 06/23/11 12:40 PM Re: Engine Blow By [Re: chevman4life]
kemo Offline
Loc: MN, USA
you can't really "slow it down". At that point, it is time to start looking for a new ride, a new engine, or parts to rebuild it.
But I guess that's just me, I'd rather fix the problem ASAP rather than play the odds that are against me.
"I change my oil every 3,000 miles, or whenever I get bored... whichever comes first." - Hank Hill
#2295792 - 06/23/11 01:00 PM Re: Engine Blow By [Re: chevman4life]
Loc: TX
Good point. Some close friends have a 2000 Ford Winstar and at around 150k it started having slight blow by, he was told to try a HM oil and add Lucas Oil Stabilizer. I remember him telling me that he hadn't noticed anymore issues with it, and since then they have put over 50k on it. His wife still drives it everyday with over 200k. I guess it depends on how bad it is.
#2295799 - 06/23/11 01:04 PM Re: Engine Blow By [Re: chevman4life]
Chris142 Offline
Loc: apple valley, ca
All engines have some blow by. As wear increases so does blow by. Using thicker oil wont do much to improve things.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#2295803 - 06/23/11 01:07 PM Re: Engine Blow By [Re: Chris142]
lexus114 Offline
Loc: Easton, PA
It help`s some. Buy`s some time if nothing else.
Edited by lexus114 (06/23/11 01:10 PM)
2012 Mercedes-Benz C300 4matic
2015 Lexus RX350 AWD
#2295815 - 06/23/11 01:20 PM Re: Engine Blow By [Re: chevman4life]
JHZR2 Offline
Loc: New Jersey
Lots of diesels have substantial blowzy and still run well. In a gasser, no such luck. If it's bad, look for a new engine.
#2295829 - 06/23/11 01:41 PM Re: Engine Blow By [Re: chevman4life]
RegDunlop Offline
Loc: NYC NY USA
Can somebody explain "blowby?"
What causes it?
How do you know, what are indications it is occurring?
#2295833 - 06/23/11 01:47 PM Re: Engine Blow By [Re: RegDunlop]
440Magnum Offline
Loc: Texas
What causes it?
"Blow by" refers to combustion gasses escaping past the rings and into the crankcase. ALL piston engines have blow-by, that's what the PCV valve and plumbing is for- to suck it away and burn it before it creates excessive deposits in the engine (and the EPA likes it because it keeps it out of the air, too).
Blow-by tends to decrease as a new engine breaks in, then slowly increase again as an engine wears out. It is only "excessive" when the volume of blow-by is more than the PCV system can remove. You know this because the engine starts venting vapor out the oil fill hole at idle (a visible grey mist when you run the engine with the oil fill cap off) and/or soaking the air filter with oil mist that gets pushed out the crankcase air inlet pipe that usually attaches to the air intake plumbing.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 Cherokee 4.0, '11 Grand Cherokee 3.6
#2295853 - 06/23/11 02:21 PM Re: Engine Blow By [Re: chevman4life]
VR1 Offline
Loc: North Texas
like stated above engine is showing its age but, I woudn't run a thicker oil or stabilizers it will not help a thing and actually cause more wear in other parts of your engine like bearings etc. Trying a high mileage is a good choice to help with it some but, use your recomended grade. Thats about all you can do until its rebuild time.
People who know use Valvoline
#2295861 - 06/23/11 02:31 PM Re: Engine Blow By [Re: chevman4life]
crw Offline
Loc: Pocatello, ID
For what it's worth, the 1.5L Mazda I have... we bought it with 147K... some time after that I realize that the engine has significant blow by... But I keep up with it, change the oil and add more when it burns off, the engine is now at 175K and still going fine. Yes, it would have been better if the PO hadn't neglected it, but if I can get it to 200K I'll consider it good.
2005 Nissan Maxima, 6-speed manual; many others...
#2295916 - 06/23/11 03:49 PM Re: Engine Blow By [Re: chevman4life]
tig1 Offline
Loc: Illinois
Excessive blow by can be caused by actual cyl wall and ring wear, or in most cases,I believe, may be caused by ring coking from oil change abuse where the rings coke solid and can't expand to the cyl wall as designed with carbon from oil that is way pasted it prime. Synthetic oil can help prevent this. I have done 10K OCIs for many years and have never experienced ring coking with synthetic oil.
2007 Ford Fusion 183,000 miles
M1 0-20 AFE
2007 Ford Focus 155,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#2296003 - 06/23/11 05:26 PM Re: Engine Blow By [Re: chevman4life]
demarpaint Offline
Loc: NY
If the rings are sticking and causing the blow-by an engine cleaning product like Kreen "could" help. Please note the word "could" help, MMO "could" as well it just takes longer. When using one of these products just keep on eye on the oil level because it could drop faster with the addition of either product. If the blow-by is caused by wear Schaeffers #132 might help.
God Bless Our Troops
#2296212 - 06/23/11 09:18 PM Re: Engine Blow By [Re: 440Magnum]
TFB1 Offline
Loc: VA
Bingo and even engines with excessive blowby can run tens of thousands miles as long as they are closely maintained... Mainly with this condition it's important to keep the oil fresh, as the blowby will quickly shear the oil and worsen the issue or possibly lead to additional problems... Of course most are going to take the attitude, it already has problems, why bother with a regular OCI...
#2296214 - 06/23/11 09:21 PM Re: Engine Blow By [Re: chevman4life]
hattaresguy Offline
Loc: CT
It doesn't really mean a whole lot as long as the engine runs well. Their are a lot of low compression older motors out their still chugging along.
Oil has very little to do with it, its wear. The only fix is a rebuild.
Edited by hattaresguy (06/23/11 09:22 PM)
#2296253 - 06/23/11 09:54 PM Re: Engine Blow By [Re: hattaresguy]
SL2 Offline
Loc: Upstate, NY
Such as my 226K mile buick century with its 1/2 shot burnt/chipped valves..
13 Optima SXL 2.0 Turbo Synthetic 5W30
02 Regal. 3.8L Series II Blend 10W30
Page 1 of 2 1 2 >
