Previously you guys and I mentioned that I might have a loose tie rod in my car because the 3/9 O'clock location has movement of 5mm or so at the trend of a 14" tire. Today I found some time to check under the car with both front wheels off the ground. The entire system from left tie rod end to right tie rod end is rigid when I try to shake left to right. It seems like the entire system has a backlash that is inside the rack or the steering linkage. How much is usually acceptable?
Similarly it seems like every FWD car I've seen have wheel rotation backlash if the other wheel is on the ground, by about 10 degrees or so. How much is usually normal?
